StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black
Quicklinx: 920LWS00 Mfr#: DP2VGAMM10B
Length: 3.05m
More than 50 in stock
£21.00 ex VAT
£25.20 inc VAT
Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 10ft long cable. The DP2VGAMM10B 10ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your new Mini DisplayPort computer to work with an older VGA monitor or projector.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 10 ft DisplayPort to VGA Adapter Cable - DP to VGA Video Converter - Active DisplayPort to VGA Cable for PC 1920x1200 - Black (DP2VGAMM10B) - DisplayPort cable - 3.05 m
DisplayPort cable
Latched
Length
3.05 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
FCC, RoHS
3-year warranty
DisplayPort cable
Latched
Length
3.05 m
Connector
20 pin DisplayPort - male
FCC, RoHS
3-year warranty
920L StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £19.54
920L StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £18.34
920L StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £18.34
920L StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.54
920L StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £26.21
920L StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £25.68
920L StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £21.00
920L StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £28.84
Length: 3.05m
Price Range Ex VAT: 0 - 50
