StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M
Quicklinx: 3ZMKWS00 Mfr#: SCNM9FM
Length: 3m
Select:
More than 50 in stock
£3.84 ex VAT
£4.60 inc VAT
This 10 ft Cross Wired Serial/Null Modem Cable features one DB9 female and one DB9 male connector, allowing you to connect a serial printer to a 9 pin serial port, or transfer files from PC to PC via serial connection. This serial/null modem cable is designed to provide a reliable, long-lasting connection.
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M - Null modem cable - DB-9 (M) to DB-9 (F) - 10 ft - SCNM9FM - null modem cable - DB-9 to DB-9 - 3 m
Null modem cable
Length
3 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
P/N: EC1S232U2, ICUSB23208FD, ICUSB23216FD, ICUSB2321FIS, ICUSB2322F, ICUSB2322I, ICUSB232IS, ICUSB232PROC, ICUSB232SM3, NETRS232, NETRS2321P, NETRS2322P, NETRS232485W, PCI2S232485I, PCI2S4851050, PCI4S954PW, PEX1S553LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX4S553, PEX4S553B
Null modem cable
Length
3 m
Connector
P/N: 10PKPCI1S550, EC1S232U2, EC1S952, EC2S952, IC485S, ICUSB232, ICUSB23208FD, ICUSB23216FD, ICUSB2321FIS, ICUSB2321X, ICUSB2322F, ICUSB2322I, ICUSB2322X, ICUSB2324X, ICUSB2328, ICUSB232DB25, ICUSB232IS, ICUSB232PROC, ICUSB232SM3, ICUSB422IS, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W, PCI1S550, PCI2S1P, PCI2S232485I, PCI2S4851050, PCI2S550, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S550N, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX4S553, PEX4S553B, PEX4S952, PEX8S950LP
Length: 3m
Price Range Ex VAT: 0 - 50
