StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F
Quicklinx: 3ZMLWS00 Mfr#: SCNM9FF
Length: 3m
Type: Serial
Select:
More than 50 in stock
£4.27 ex VAT
£5.12 inc VAT
This 10 ft Cross Wired Serial/Null Modem Cable features two DB9 female connectors, allowing you to connect a serial printer to a 9-pin serial port, or transfer files from PC to PC via serial connection. This serial/null modem cable is designed to provide a reliable, long-lasting connection.
StarTech.com 10' RS232 Serial Null Modem Cable - null modem cable - 3 m
Null modem cable
Length
3 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
P/N: PEX1S553, PEX2S553LP, PEX2S553, PEX1S553LP, PCI2S232485I, PEX16S952LP, PCI8S950LP, PEX1S552LP, PEX2S552LP, PEX4S952LP, ECS0016GB, ECS0016, PEX2S552, PEX1S552, PEX8S950LP, PEX4S950, PEX4S550, NETRS2321E, EC4S950, CB1S485, CB2S950, PEX2S950, CB1PECP, EC2S950, EC1S950, CB4S950, PCI2S950DV
Null modem cable
Length
3 m
Connector
StarTech.com 1 Port CardBus PCMCIA Parallel Laptop Adapter Card, 1 Port CardBus PCMCIA RS422 RS485 Serial Laptop Adapter Card, 1 Port ExpressCard RS232 Serial Adapter Card with 16950 UART, 1 Port ISA RS232 Serial Adapter Card with 16550 UART, 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 1 port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 1 Port PCI Dual Voltage Parallel Adapter Card, 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART, 1 Port PCI RS232 Powered Serial Adapter Card, 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 1 Port PCI RS232 Serial Adapter Card with 16550 UART, 1 Port RS-232/422/485 Serial over IP Ethernet Device Server, 16 Port Enhanced RS232 Serial Console Server, 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included, 2 Port CardBus RS232 Serial Laptop PC Adapter Card - 16950, 2 Port ExpressCard Serial Adapter Card, 2 Port ISA RS232 Serial Adapter Card with 16550 UART, 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 2 Port PCI RS232 Serial Adapter Card with 16550 UART, 2 Port RS232/422/485 PCI Serial Adapter Card w/ ESD Protection, 2S1P PCI Serial Parallel Combo Card with 16550 UART, 4 Port 16950 Serial CardBus Adapter, 4 Port ExpressCard 16C950 Serial Card, 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART, 4 Port PCI Dual Profile RS232 Powered Serial Adapter Card, 4 Port PCI Express RS232 Serial Adapter Card with 16950 UART, 4 Port PCI Express Serial Card, 4 Port PCI RS232 Serial Adapter Card, 4 port PCI RS232 Serial Adapter Card with 16550 UART, 8 Port Low Profile RS232 PCI Serial Card with 16950 UART, 8 Port PCI Express Low Profile Serial Adapter Card
Length: 3m
Type: Serial
Price Range Ex VAT: 0 - 50
