StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F
Quicklinx: 3ZMLWS00 Mfr#: SCNM9FF
Length: 3m
Type: Serial
Select:
£4.33 ex VAT
£5.19 inc VAT
This 10 ft Cross Wired Serial/Null Modem Cable features two DB9 female connectors, allowing you to connect a serial printer to a 9-pin serial port, or transfer files from PC to PC via serial connection. This serial/null modem cable is designed to provide a reliable, long-lasting connection.
StarTech.com 10' RS232 Serial Null Modem Cable - Null modem cable - DB-9 (F) to DB-9 (F) - 10 ft - SCNM9FF - null modem cable - 3 m
Null modem cable
Length
3 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
P/N: EC1S232U2, EC1S952, EC2S952, ICUSB232DB25, ICUSB232INT1, ICUSB232INT2, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W, PCI2S232485I, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S953, PEX2S953LP, PEX4S232485, PEX4S553, PEX4S553B
Null modem cable
Length
3 m
Connector
P/N: 10PKPCI1S550, EC1S232U2, EC1S952, EC2S952, IC485S, ICUSB232DB25, ICUSB232INT1, ICUSB232INT2, ICUSB422IS, NETRS232, NETRS2321P, NETRS2321POE, NETRS2322P, NETRS232485W, PCI1S550, PCI2S1P, PCI2S232485I, PCI2S550, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S550N, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S953, PEX2S953LP, PEX4S232485, PEX4S553, PEX4S553B, PEX4S952, PEX8S950LP, ST121UTP232
Length: 3m
Type: Serial
Price Range Ex VAT: 0 - 50
