Your basket is empty
StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M
Quicklinx: 3ZMMWS00 Mfr#: SCNM925FM
Length: 3m
More than 50 in stock
£3.88 ex VAT
£4.65 inc VAT
Standard delivery Delivered within 3-5 working days
Connect your serial devices, and transfer your files. The SCNM925FM 10ft Cross Wired Serial/Null Modem Cable features one DB9 female and one DB25 male connector, allowing you to connect a 9-pin serial device to a 25-pin serial port, or transfer files from PC-to-PC via a serial connection.
StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M - null modem cable - 3 m
Null modem cable
Length
3 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
25 pin D-Sub (DB-25) - male
P/N: PEX1S553, PEX2S553LP, PEX2S553, PEX1S553LP, PCI2S232485I, PEX16S952LP, PCI8S950LP, PEX1S552LP, PEX2S552LP, PEX4S952LP, PEX2S552, PEX1S552, PCI2S485LP, ICUSB2321X, PEX8S950LP, PEX4S950, PEX4S550, PCI2S485, ICUSB2328, EC4S950, CB1S485, CB2S950, PEX2S950, CB1PECP, EC2S950, EC1S950, CB4S950
Null modem cable
Length
3 m
Connector
StarTech.com 1 Port CardBus PCMCIA Parallel Laptop Adapter Card, 1 Port CardBus PCMCIA RS422 RS485 Serial Laptop Adapter Card, 1 Port ExpressCard RS232 Serial Adapter Card with 16950 UART, 1 Port ISA RS232 Serial Adapter Card with 16550 UART, 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 1 port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART, 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 1 Port PCI RS232 Serial Adapter Card with 16550 UART, 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included, 2 Port CardBus RS232 Serial Laptop PC Adapter Card - 16950, 2 Port ExpressCard Serial Adapter Card, 2 Port ISA RS232 Serial Adapter Card with 16550 UART, 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 2 Port Low Profile PCI RS-422/485 Card, 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 2 Port PCI RS232 Serial Adapter Card with 16550 UART, 2 Port PCI RS422 RS485 DB9 Serial Adapter Card, 2 Port PCI RS422/485 Serial Adapter Card With DB9, 2 Port RS232/422/485 PCI Serial Adapter Card w/ ESD Protection, 2 Port USB to RS232 Serial DB9 Adapter Cable, 2 Serial/1 Parallel Port Dual Voltage WHQL PCI Card, 2S1P PCI Serial Parallel Combo Card with 16550 UART, 4 Port 16950 Serial CardBus Adapter, 4 Port ExpressCard 16C950 Serial Card, 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART, 4 Port PCI Express RS232 Serial Adapter Card with 16950 UART, 4 Port PCI Express Serial Card, 4 Port PCI RS232 Serial Adapter Card, 4 port PCI RS232 Serial Adapter Card with 16550 UART, 8 Port Low Profile RS232 PCI Serial Card with 16950 UART, 8 Port USB to RS232 Serial DB9 Adapter Hub
Length: 3m
Price Range Ex VAT: 0 - 50
