StarTech.com 10 ft Coax High Resolution VGA Monitor Extension Cable -  HD15 M/F
Quicklinx: 3ZK4WS00 Mfr#: MXT101HQ10
Type: SVGA
Length: 3m
£10.05 ex VAT
£12.06 inc VAT
This 10ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 10 ft High-Res Coaxial SVGA Monitor Extension Cable M/F - VGA extension cable - 3 m
VGA extension cable
Coaxial
Molded, ferrite bead
Length
3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
FCC
P/N: HDMI2VGA, AGPVID5500A, VS815RVGAGB, VS415RVGAGB, VS415RVGA
VGA extension cable
Coaxial
Length
3 m
Connector
15 pin HD D-Sub (HD-15) - female
FCC
StarTech.com 4 Port High Resolution VGA Video Switch with Remote, 8 Port VGA Video Selector Switch, HDMI to VGA Video Adapter Converter w/ Audio HD to VGA Monitor
3ZK4 StarTech.com 10 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £10.05
3ZK4 StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £17.08
3ZK4 StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £11.55
Type: SVGA
Length: 3m
Price Range Ex VAT: 0 - 50
