StarTech.com 10 ft Coax High Resolution 90 degree Upward Angled VGA Monitor Cable - HD15 M/M
Quicklinx: 6LC3WS00 Mfr#: MXT101MMHU10
Connect your VGA monitor with the highest quality connection available, even in tight spaces. This 10ft upward-angle VGA cable is designed to support the highest resolutions and highest video quality possible through VGA while fitting perfectly in tight connection spaces. The cable features one standard VGA connector (HD15) and one VGA connector (HD15) that is situated on an upward angle relative to the shaft of the cable, requiring only 32.4mm of space at the connection point.
Suited for high resolution VGA applications (1280x1024 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
StarTech.com Coax High Resolution 90° Upward Angled VGA Monitor Cable - VGA cable - 3 m
VGA cable
90° connector, ferrite bead
Length
3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
P/N: HDMIPLATE, VGAPLATE
VGA cable
American Wire Gauge (AWG)
28
Length
3 m
Connector
RoHS
6LC3 StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.42
6LC3 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £7.06
6LC3 StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £7.03
