StarTech.com 10 ft Coax High Resolution 90 degree Down Angled VGA Monitor Cable - HD15 M/M
Quicklinx: 6LC6WS00 Mfr#: MXT101MMHD10
Connect your VGA monitor with the highest quality connection available, even in tight spaces. This 10ft High Resolution Video VGA Cable (90 degree) is designed to provide the highest video quality possible through a VGA connection and is specifically constructed to accommodate tight installation spaces.
The high quality, shielded coax VGA cable features a 90 degree down-angled plug, which requires only 32.4mm (1.27") of space to make the video connection.
More than suitable for high-res VGA applications (1280x1024 resolution and above), the 90 degree VGA cable eliminates picture "ghosting" and fuzzy images that are common with non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
This 10ft High Resolution Video VGA Cable (90 degree) is designed to provide the highest video quality possible through a VGA connection and is specifically constructed to accommodate tight installation spaces. Features a 90 degree down-angled plug.
StarTech.com 10 ft High Resolution 90 Degree Down Angled VGA Monitor Cable - VGA cable - 3 m
VGA cable
90° connector, ferrite bead
Length
3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
P/N: SV221NANOU, SV231UAF
VGA cable
American Wire Gauge (AWG)
28
Length
3 m
Connector
RoHS
6LC6 StarTech.com DVI to VGA Cable Adapter - M/F In Stock £5.42
6LC6 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £7.06
6LC6 StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £7.03
