StarTech.com 10 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 10ft Patch Cord
Quicklinx: 8CPDWS00 Mfr#: RJ45PATCH10
Length: 3m
Colour: Blue
More than 50 in stock
£3.21 ex VAT
£3.85 inc VAT
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The 45PATCH10BL Cat5e Patch Cable (10 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This RJ45 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com Cat5e Ethernet Cable10 ft - Blue - Patch Cable - Snagless Cat5e Cable - Network Cable - Ethernet Cord - Cat 5e Cable - 10ft - patch cable - 3 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: BOX4HDECP, BOX4HDECP2, DK30A2DH, DKT30CDVPD, DKT30CSDHPD, DKT30CSDHPD3, ET91000SM10, ET91000SM20, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, MST30C2DPPD, MST30C2HDPPD, MST30C2HHPD, MST30C2HHPDU, PEXUSB3S3GE, PM1115P2, PM1115U2, SFP1000TXST, ST1000SPEX42, ST1000SPEX43, ST4000SPEXI, USB2HDCAPS
Network Cable Type
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Snagless
Length
3 m
Blue
Connector
RJ-45 - male
RJ-45 - male
UL
P/N: 45PATCH25WH, BOX4HDECP, BOX4HDECP2, CABCONS1716I, DK30A2DH, DKT30CDVPD, DKT30CSDHPD, DKT30CSDHPD3, ET91000SM10, ET91000SM20, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, MST30C2DPPD, MST30C2HDPPD, MST30C2HHPD, MST30C2HHPDU, PANEL4512, PEXUSB3S3GE, PM1115P2, PM1115U2, ROLLOVER, SFP1000TXST, ST1000SPEX42, ST1000SPEX43, ST4000SPEXI, SV565UTP, SV565UTPU, SV565UTPUL, USB2HDCAPS
8CPD StarTech.com 10 ft Cat5e Gray Snagless RJ45 UTP Cat 5e Patch Cable In Stock £3.21
8CPD StarTech.com 10 ft Cat5e red Snagless RJ45 UTP Cat 5e Patch Cable In Stock £3.21
8CPD StarTech.com 10 ft Cat5e Yellow Snagless RJ45 UTP Cat 5e Patch Cable In Stock £3.25
8CPD StarTech.com 10 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 10ft Patch Cord In Stock £3.21
8CPD StarTech.com 10 ft Cat5e Green Snagless RJ45 UTP Cat 5e Patch Cable In Stock £3.21
Length: 3m
Colour: Blue
Price Range Ex VAT: 0 - 50
