StarTech.com 10 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
Quicklinx: 7B56WS00 Mfr#: C6ASPAT10BL
Length: 3.05m
Colour: Blue
16 in stock
£12.15 ex VAT
£14.58 inc VAT
Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high level of performance and is an excellent choice for Power over Ethernet (PoE) applications. Plus, Cat 6a cables are backward-compatible with Cat5e and Cat6 cables, ensuring versatile network connection options. All of the Cat 6a cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that the Cat 6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
StarTech.com 10 ft Blue Cat6a / Cat 6a Shielded Patch Cable 10ft - patch cable - 3.05 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Wiring Scheme
T568B
Shielding Material
Aluminium-polyester foil
Molded
Length
3.05 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: BNDTB10GI, SFP10GBTST, ST10000SPEXI, ST10GPEXNDPI, ST10GSPEXNB, ST20000SPEXI, ST5GPEXNB
Network Cable Type
Wiring Scheme
T568B
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Molded
Length
3.05 m
Blue
Connector
RJ-45 - male
RJ-45 - male
UL 444, RoHS - up to 500 MHz
Length: 3.05m
Colour: Blue
Price Range Ex VAT: 0 - 50
