StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable
Quicklinx: 4011WS00 Mfr#: C6PATCH10BL
Length: 3m
Colour: Blue
£3.83 ex VAT
£4.59 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH10BL Cat 6 Patch Cable (10 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Gigabit Patch Cable delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This molded patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 10 ft Blue Cat6 / Cat 6 Molded Patch Cable 10ft - patch cable - 3 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: ST1000SPEX4, ET91000LC, ET91000SM40
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
3 m
Blue
Connector
RJ-45 - male
RJ-45 - male
CSA, ETL - up to 650 MHz
StarTech.com 1000 Mbps Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km, 4 Port PCI Express Gigabit Ethernet NIC Network Adapter Card
Length: 3m
Colour: Blue
Price Range Ex VAT: 0 - 50
