Product
StarTech.com 10/100 VDSL2 Ethernet Extender Kit over Single Pair Wire – 1km
Quicklinx: 6BD4WS00 Mfr#: 110VDSLEXTGB
Type: Misc
£243.16 ex VAT
£291.79 inc VAT
Extend your 10/100Mbps network by up to 1km over Ethernet or RJ11 phone lines.
The 110VDSLEXTGB VDSL Ethernet extender kit allows you to span a 10/100 network over extremely long distances (up to 1km) while still maintaining high-speed network connectivity.
The device allows you to run the connection over standard RJ45 cabling, existing RJ11 phone lines, or any other set of single pair wires.
The VDSL (VDSL2) kit is simple to install and provides an out-of-the-box solution as both the Ethernet-VDSL extender and receiver units are included. A perfect solution for a broad range of applications including connecting isolated user stations within the same building or between separate buildings, or overcoming infrastructure obstacles and distances (e.g. older stone/concrete architecture) where new wiring or wireless may be impossible.
The VDSL Ethernet LAN Extender kit helps to eliminate expense by allowing video streaming and data to share the same telephone pair without interference.
The 110VDSLEXT requires only a single pair of wires to function, while offering the ability to use multiple sets of the devices to create several simultaneous connections to your remote building. In these multiple set configurations, you have the ability to use up to 4 sets over a single Cat5e or Cat6 cable which can be used as separate LAN (or VLAN) connections, or bridged into a trunk line for additional speed/bandwidth over long distances (up to two sets only over standard Cat5).
Package includes - 1 Extender, 1 Receiver, 2 RJ45 to VSDL cable, 2 Power Supply Units, 1 Instruction Manual
StarTech.com 10/100 VDSL2 Ethernet Extender Kit over Single Pair Wire - short-haul modem - 10Mb LAN, 100Mb LAN, Ethernet over VDSL
Short-haul modem
External
United Kingdom
Cabling Type
10Base-T, 100Base-TX
Max Transfer Distance
1 km
7.2 cm x 9.5 cm x 2.2 cm
90 g
2 years warranty
Short-haul modem
External
United Kingdom
Wired
Cabling Type
1 km
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
1 x Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x modem - VDSL2 - RJ-45
FCC, RoHS
External power adapter
7.2 cm
9.5 cm
2.2 cm
90 g
50 °C
5 - 95%
6BD4 StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £4.58
6BD4 StarTech.com 25 ft RJ11 Telephone Modem Cable In Stock £3.78
Type: Misc
Price Range Ex VAT: 150 - 300
