StarTech.com 10/100 PoE Power over Ethernet Splitter 5V/12V
Quicklinx: 7P14WS00 Mfr#: POESPLT100
The POESPLT100 10/100 Mbps PoE Power over Ethernet Splitter with 5-12V Output separates the data and power connections received from your Power Sourcing Equipment(PSE) such as a single port PoE injector or a PoE Switch.
At the remote end of your PoE connection, the POESPLT100 gives you a standard DC jack with selectable 5, 7.5, 9 or 12V output and separate Ethernet data connection allowing you to take advantage of power of Ethernet infrastructure, and use a variety of peripherals in places where no wall outlet exists.
StarTech.com 10/100 PoE Power over Ethernet Splitter 5V/12V - PoE splitter - 19.2 Watt
PoE splitter - external
240 g
Output Voltage
5 / 7.5 / 9 / 12 V
Power Capacity
19.2 Watt
Output connectors
1 x RJ-45
Silver
7.5 cm x 10.2 cm x 2.2 cm
Silver
1 x RJ-45
Output Voltage
5 / 7.5 / 9 / 12 V
Power Capacity
19.2 Watt
FCC, RoHS
45 °C
10 - 90% (non-condensing)
7.5 cm
10.2 cm
2.2 cm
240 g
7P14 StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £244.42
