StarTech.com 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC 20km
Quicklinx: 85DFWS00 Mfr#: ET90110WDM2
Type: Media Converter
Hurry, only 2 left in stock!
£239.09 ex VAT
£286.90 inc VAT
Convert and extend a 10/100 Mbps Ethernet connection up to 12.4 miles/20 km over a single mode SC fiber cable. The ET90110WDM2 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC (20km) lets you extend a 10/100 Mbps Ethernet connection over single mode fiber, at distances up to 20 km (12.4 mi).
The converter offers Wavelength-Division Multiplexing (WDM), enabling bi-directional communication over a single strand of fiber, essentially doubling the capacity of your existing fiber infrastructure without having to install new cabling.
The Ethernet to WDM Fiber Kit includes both endpoints (two interchangeable modules) - a simple solution for connecting 10/100Base-T networks to remote locations using SC-terminated single mode fiber. The Ethernet to Fiber Converter also features a durable all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or one or both sides can be installed into a 20 Slot, 2U Rackmount Chassis (ETCHS2U).
StarTech.com Ethernet SM WDM Fiber Media Converter Kit SC 20km - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / SC single-mode
External
North America, United Kingdom, Europe
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
20 km
AC 120/230 V
9.5 cm x 16 cm x 2 cm
1.2 kg
External
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
20 km
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
IEEE 802.3, IEEE 802.3u
2 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 2 x Ethernet 100Base-FX - SC single-mode female x 2
FCC, RoHS
External power adapter
Installed Qty
2
AC 120/230 V
9.5 cm
16 cm
2 cm
1.2 kg
60 °C
10 - 90%
85DF StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £4.73
85DF StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.83
85DF StarTech.com 10/100 Mbps Ethernet Single Mode WDM Fiber Media Converter Kit SC 20km In Stock £239.09
85DF StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converter In Stock £483.18
Price Range Ex VAT: 150 - 300
