Print directly from your iPhone / iPod touch / iPad devices to a standard USB printer. The PM1115UA Wireless-N USB AirPrint Server lets you print directly from your iPhone, iPod touch or iPad devices to most standard USB printers over a wireless network.
With this compact AirPrint server connected to your existing wireless network, it enables iOS / iPad printing direct from the print menu of your device, without the hassle of transferring your documents or photos to another system.
You can also use the AirPrint server with other laptop and desktop systems on your network, effectively turning any standard USB printer into a fully networked printer. This compact server supports 802.11b/g/n standards and features an easy-to-use web interface as well as print management software for Windows and Mac OS . For added flexibility, up to 2 printers can be connected to the print server using a USB hub (not included).
As an added benefit, using a wireless print server makes your printer available from anywhere within range of your wireless router, so you can place it in a convenient location without being tied down by a network cable.
- StarTech.com 1 Port USB Wireless-N 150Mbps AirPrint Server - device server
- Device server
- Form Factor
- External
- Data Link Protocol
- Ethernet, USB, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- OS Required
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Apple MacOS X 10.8 or later, Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits), Windows 10 (32/64 bits)
- 5.5 cm x 7.5 cm x 2 cm
- 50 g
- 2-year warranty
- Device server
- 5.5 cm
- 7.5 cm
- 2 cm
- 50 g
- Enclosure Colour
- Black
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- TCP/IP
- Status Indicators
- Power, WLAN, LAN, USB
- Apple AirPlay
- Encryption Algorithm
- AES, TKIP, WPA, WEP
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 1 x 100Base-TX - RJ-45 , 1 x USB - Type A
- UL, FCC, RoHS
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 70%
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
