StarTech.com 1 Port USB to RS232 DB9 Serial Adapter with Detachable 6ft USB A to B Cable
Quicklinx: B0N2WS00 Mfr#: ICUSB232D
Type: Serial adapter
Compatibility: Android, Mac, PC, Unix
Interface: USB 2.0
Hurry, only 3 left in stock!
£8.23 ex VAT
£9.87 inc VAT
Express delivery Order within the next 4 hours for delivery tomorrow
Add an RS232 serial port to your laptop or desktop computer through a detachable USB cable. The ICUSB232D 1 Port USB to Serial Adapter lets you add an RS232 DB9 serial port to your laptop or desktop computer through USB, so you can connect to, monitor and control a serial device. For easy connections, the adapter features a female USB type-B port, so you can choose the length of USB cable needed to reach your serial device (6ft / 1.8m USB A-B cable included).
The USB to RS232 adapter is a convenient and cost-saving solution for providing legacy serial connectivity to devices such as point-of-sale terminals, serial modems, industrial equipment and a wide variety of other RS232 peripherals.
The USB to serial converter is easy to install and offers broad operating system compatibility including Windows, Mac OS and Linux for easy integration into mixed environments, and offers support for transfer rates up to 128 Kbps.
StarTech.com USB to Serial Adapter - Detachable 6 ft USB A-B Cable - Prolific PL-2303 - USB to RS232 Adapter Cable (ICUSB232D) - serial adapter
Serial adapter
External
Interface (Bus) Type
USB 2.0
3.2 cm x 5.9 cm x 2.2 cm
Grey
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Android, Microsoft Windows Server 2012, Apple MacOS X 10.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 (32/64 bits), Windows 10 (32/64 bits)
Serial adapter
External
USB 2.0
Wired
USB powered
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB cable (external) - 1.8 m
FCC, RoHS
Grey
Software Included
Drivers & Utilities
3.2 cm
5.9 cm
2.2 cm
70 °C
5 - 95% (non-condensing)
B0N2 StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.35
B0N2 StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.83
B0N2 StarTech.com 3 ft A Right Angle to B Right Angle USB Cable - M/M In Stock £4.16
B0N2 StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £16.61
B0N2 StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £16.18
B0N2 StarTech.com 3 ft Straight Through Serial Cable - DB9 M/F In Stock £3.30
B0N2 StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.01
B0N2 StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.30
B0N2 StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £3.29
B0N2 StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M In Stock £29.53
B0N2 StarTech.com Micro USB to RS232 DB9 Serial Adapter Cable for Android with USB Charging - M/M In Stock £22.04
B0N2 StarTech.com 1 Port USB to RS232 DB9 Serial Adapter with Detachable 6ft USB A to B Cable In Stock £8.23
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Interface: USB 2.0
Price Range Ex VAT: 0 - 50
