Add an RS232 serial port to your laptop or desktop computer through a detachable USB cable. The ICUSB232D 1 Port USB to Serial Adapter lets you add an RS232 DB9 serial port to your laptop or desktop computer through USB, so you can connect to, monitor and control a serial device. For easy connections, the adapter features a female USB type-B port, so you can choose the length of USB cable needed to reach your serial device (6ft / 1.8m USB A-B cable included).
The USB to RS232 adapter is a convenient and cost-saving solution for providing legacy serial connectivity to devices such as point-of-sale terminals, serial modems, industrial equipment and a wide variety of other RS232 peripherals.
The USB to serial converter is easy to install and offers broad operating system compatibility including Windows, Mac OS and Linux for easy integration into mixed environments, and offers support for transfer rates up to 128 Kbps.
- StarTech.com USB to Serial Adapter - Detachable 6 ft USB A-B Cable - Prolific PL-2303 - USB to RS232 Adapter Cable (ICUSB232D) - serial adapter - USB 2.0
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 3.2 cm x 5.9 cm x 2.2 cm
- Grey
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 3.5.x - 4.11.x LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wired
- USB powered
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Cables Included
- 1 x USB cable (external) - 1.8 m
- FCC, RoHS
- Grey
- Software Included
- Drivers & Utilities
- OS Required
- 3.2 cm
- 5.9 cm
- 2.2 cm
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 95% (non-condensing)
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.75 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.33 |
StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £14.48 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.05 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £102.11 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £175.88 |
StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.76 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.33 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.46 |
StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M | In Stock | £38.26 |
StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £33.80 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.35 |
StarTech.com 3m USB 2.0 A to Left Angle B Cable - M/M | In Stock | £4.68 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £79.29 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £392.42 |
