StarTech.com 1 Port USB PS/2 Server Remote Control IP KVM Switch with Virtual Media
Quicklinx: 93K5WS00 Mfr#: SV1108IPEXGB
Type: KVM switch
Connectivity: KVM
Ports: 1
Hurry, only 3 left in stock!
£247.85 ex VAT
£297.42 inc VAT
Control a server or PC remotely over the Internet, with virtual media remote file copying and installation. The SV1108IPEXGB 1 Port USB PS/2 Server Remote Control IP KVM Switch with Virtual Media lets you control a USB or PS/2 server remotely over a LAN or the Internet.
The 1 port KVM over IP includes all necessary KVM cables, and offers KVM control from the BIOS-level onward. Reboot, monitor the entire boot process, and interact with your connected system easily. RS232 support also lets you connect to a serial console device via Telnet or SSH.
Virtual Media lets you execute files via USB from the remote console as if they were local to the connected server. Perfect for remote driver updates, patches, application or OS installation.
The Java-based browser utility ensures the IP remote control unit is compatible with many current web browsers, and almost any operating system on the market.
Multiple integrated security features ensure a reliable single port IP KVM connection, including password-protection, IP/MAC address filtering, external authentication (RADIUS, LDAP, LDAPS, Active Directory) and advanced encryption (56-bit DES, 168-bit 3DES, 256-bit AES, 128-bit RC4).
StarTech.com 1 Port Server Remote Control IP KVM Switch w/ Virtual Media - KVM switch
KVM switch
Subtype
KVM
Remote Management Protocol
HTTP, HTTPS
128-bit encryption, DHCP support, MAC address filtering
8.15 cm x 20 cm x 2.5 cm
490 g
KVM switch
Enclosure Type
Desktop
Subtype
KVM
Keyboard / Mouse Interface
PS/2, USB
HTTP, HTTPS
Encryption Algorithm
DES, Triple DES, RC4, AES, 128-bit WEP, SSL
Authentication Method
Secure Shell (SSH)
Max Resolution
1600 x 1200 @ 60 Hz
Status Indicators
Power, link/activity
2 x VGA HD-15 , 2 x keyboard (PS/2) , 2 x mouse (PS/2) , 3 x USB , 1 x mini-USB Type B , 1 x serial (RS-232) DB-9 , 1 x RJ-45
External power adapter
1 x keyboard / mouse / video cable
Rack Mounting Kit
Included
8.15 cm
20 cm
2.5 cm
490 g
50 °C
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
93K5 StarTech.com 6 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.35
Type: KVM switch
Connectivity: KVM
Ports: 1
Price Range Ex VAT: 150 - 300
