StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m)
Quicklinx: 87P0WS00 Mfr#: USB110EXT2
Type: Extender
£103.22 ex VAT
£123.86 inc VAT
Extend a USB 1.1 device up to 40m (131ft) away from a computer, over a Cat5/Cat6 cable. The USB110EXT2 USB 1.1 Extender enables you to extend a USB 1.1 connection over distances of up to 40-meters (131-feet) using standard Cat5 or Cat6 UTP cabling, bypassing the normal limitation of 5m (15ft) for USB 1.1 devices and allows for the host computer system to be safely stored in a remote location.
The USB Extender features a compact design with no external power requirements, making it the ideal solution for remote USB cameras, keyboards, mice or other input devices for environments where install space or access to electrical outlets is limited.
Able to deliver up to 300mA of power (when supplied with 500mA from the host computer), the extender is fully compliant with the USB 1.1 specification, with support for up to 12Mbps of data bandwidth.
StarTech.com 1-Port USB 1.1 Extender - Up to 131 ft (40 m) over Cat5/Cat6 Extension - Up to 12 Mbps USB 1.1 Ethernet Extender (USB110EXT2) - USB extender - USB
USB extender
External
Data Transfer Rate
12 Mbps
USB
Transmission Medium
CAT 5/6
Max Transfer Distance
40 m
Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7
2.5 cm x 8.5 cm x 4 cm
50 g
3-year warranty
P/N: UUSBOTG
USB extender
External
Wired
USB
Data Transfer Rate
12 Mbps
40 m
USB powered
USB 1.1
1 x USB - Type A female , 1 x USB - Type A male , 2 x - RJ-45 female
FCC, RoHS
2.5 cm
8.5 cm
4 cm
50 g
Limited warranty - 3 years
50 °C
20 - 90%
P/N: UUSBOTG
87P0 StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £4.95
87P0 StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.17
87P0 StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.26
87P0 StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £384.67
87P0 StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) In Stock £103.22
87P0 StarTech.com 1000 ft Bulk Roll of Gray CMR Cat5e Solid UTP Cable In Stock £207.51
87P0 StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.34
87P0 StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) In Stock £169.42
87P0 StarTech.com 1 Port USB 2.0 Extender Kit In Stock £134.12
87P0 StarTech.com 4-Port USB 2.0 Extender Hub In Stock £381.13
Type: Extender
