Extend one USB 2.0 connection up to 330ft away from the computer over Cat5 or Cat6 cable. The USB2001EXT2 USB over Cat5/Cat6 Extender lets you extend a USB 2.0 connection over distances of up to 100-meters (330-feet), over standard Cat5 or Cat6 Ethernet cabling.
Backward compatible with USB 1.x devices, the extender enables almost any kind of USB device to be placed at remote locations away from the host computer system.
With data bandwidth of up to 480 Mbps and no software installation required, the USB extender offers a fast, easy, and versatile solution for business or industrial applications with durable metal housing, an included surface-mounting bracket kit, and simple plug-and-play installation.
Plus, the extender provides up to the full 500 mA of power (with the use of an external power adapter at the remote end) allowing for greater compatibility with bus-powered USB devices.
- StarTech.com Newer version is USB2001EXT2NA - 1 Port USB 2.0 over Cat5 / Cat6 Ethernet Extender - up to 330ft (100m) (USB2001EXT2) - USB extender - USB 2.0
- USB extender
- Form Factor
- External
- Data Transfer Rate
- 480 Mbps
- Data Link Protocol
- USB 2.0
- Transmission Medium
- CAT 5/6
- Max Transfer Distance
- 100 m
- Power
- AC 120/230 V
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits)
- 2-year warranty
- Designed For
- P/N: SVA5M4NEUA
- USB extender
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- USB 2.0
- 480 Mbps
- 100 m
- Status Indicators
- Power, active, host, link/activity, USB
- USB 2.0
- 1 x USB 2.0 - Type A female , 1 x USB 2.0 - Type B female , 2 x - RJ-45 female
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 20 - 90%
- Designed For
- P/N: SVA5M4NEUA
StarTech.com 6in Mini USB 2.0 Cable - A to Mini B | In Stock | £4.05 |
StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable | In Stock | £384.67 |
StarTech.com 75 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £29.25 |
StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £36.45 |
StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) | In Stock | £103.22 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.94 |
StarTech.com 1000 ft Bulk Roll of Gray CMR Cat5e Solid UTP Cable | In Stock | £207.51 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.63 |
StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) | In Stock | £169.37 |
StarTech.com 1 Port USB 2.0 Extender Kit | In Stock | £134.21 |
StarTech.com DC Power Adapter - 5V, 4A | In Stock | £13.29 |
