StarTech.com 1 Port USB 2.0 Extender Kit
Quicklinx: D5BPWS00 Mfr#: USB2001EXT2P
Hurry, only 3 left in stock!
£296.22 ex VAT
£355.46 inc VAT
Connect a USB 2.0 device to your computer up to 100 m (330 ft) away, and power the USB extender from the local or remote side. This single-port USB 2.0 extender lets you access and use your USB device up to 100 m away over Cat5e or Cat6 cable. And, because it can be powered by either the local or the remote unit, you have more flexibility to place your USB device exactly where you need it. It's the perfect USB extension solution for warehouses, factories, classrooms, boardrooms, homes, or offices.
Many USB-to-Ethernet extenders require that the remote unit has a power source connected for operation, which can make installation difficult. This versatile extender overcomes that restriction, letting you connect the power adapter to either the local (transmitter) unit or the remote (receiver) unit as needed.
When the power adapter is connected to the local unit, the extender delivers power over your Cat5e or Cat6 cable, eliminating the need for a power adapter in the remote location. Now you have the added convenience to install your USB device even in a remote location where a power outlet is unavailable, up to 100 m away.
This USB extender overcomes the 16 ft. cable length limitations of traditional USB 2.0 cables, so you can create a more efficient, more flexible workspace. It's perfect for connecting webcams, printers, flash drives, and virtually any USB peripheral.
Plus, with the included power adapter, you can connect power-hungry USB devices such as external hard drives. For added installation convenience, the USB-to-Ethernet extender features built-in cable-tie slots for mounting to a pole.
The USB 2.0-over-Cat5-or-Cat6 extender is multi-platform compatible, so it supports a variety of operating systems such as Windows, Mac, Linux and Chrome OS . Setup is easy with no additional drivers or software required, and the universal USB extender is backward compatible with USB 1.1 and 1.0 peripherals.
StarTech.com 1 Port USB 2.0 over Cat5 or Cat6 Extender Local / Remote Power - USB extender - USB 2.0
USB extender
External
Data Transfer Rate
480 Mbps
USB 2.0
Max Transfer Distance
100 m
AC 120/230 V
3 cm x 8.8 cm x 6.5 cm
620 g
USB extender
External
Wired
USB 2.0
Data Transfer Rate
480 Mbps
100 m
Status Indicators
Power, host, link/activity
USB 2.0
1 x USB - Type A female , 1 x USB - Type A male
1 x USB cable
FCC, RoHS
External power adapter
AC 120/230 V
24 Watt
3 cm
8.8 cm
6.5 cm
620 g
50 °C
20 - 80% (non-condensing)
Price Range Ex VAT: 150 - 300
