This 1 Port SATA to SATA Slot Plate Bracket adds external data support to any existing Serial ATA controller. Installation is easy: just install the plate into an open I/O slot on your computer and connect the cables to the Serial ATA connectors on your motherboard or controller card. The slim SATA data cable provides less clutter for increased airflow inside your case.
- StarTech.com 1 Port SATA to SATA Slot Plate Bracket - SATA to eSATA cable - 30.5 cm
- Interface Speed
- Serial ATA 150
- Length
- 30.5 cm
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- 7 pin Serial ATA - male
- Limited lifetime warranty
- Designed For
- P/N: PATA2SATA3
- Storage Cable Type
- Interface Speed
- Serial ATA 150
- Length
- 30.5 cm
- Connector
- Designed For
- P/N: PATA2SATA3
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.34 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.58 |
Customer reviews
Write a review for the StarTech.com 1 Port SATA to SATA Slot Plate Bracket here!
Be warned - this is NOT an eSATA backplate
Reviewed by Anonymous Review Posted 30/10/2007
The description doesn't make it very clear, but this is NOT an eSATA backplate. It's actually a normal (internal) SATA connector on the backplate!
But otherwise it seems quite nice, and it even has a plastic plug to protect the SATA connector (from dust) when not in use.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
