Product
StarTech.com 1 Port SATA to eSATA Slot Plate Bracket
Quicklinx: 8CF7WS00 Mfr#: ESATAPLATE1
Length: 30cm
10 in stock
£5.10 ex VAT
£6.12 inc VAT
StarTech.com's eSATA SATA adapter plate adds external data support to any existing Serial ATA controller. The adapter plate can be mounted to the rear panel of the computer case, providing straightforward eSATA to SATA connections allowing users to connect their eSATA device (hard drive enclosure, etc.) to the provided eSATA port which is an extension of the motherboard SATA data connector.
Designed to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections, the eSATA SATA adapter supports data transfer rates of up to 6 Gbps.
StarTech.com 1 Port SATA to eSATA Slot Plate Bracket - SATA internal to external panel - 30 cm
Interface Speed
Serial ATA 150/300/600
Length
30 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
7 pin external Serial ATA - male
P/N: SAT5210U2EGB, SAT5210U2E, SAT2510U2E, SAT3550ESR, ECESATA22, SAT3510U2E, ESATCASE2
Storage Cable Type
Interface Speed
Length
30 cm
Connector
StarTech.com 2 Port ExpressCard eSATA Controller Adapter Card, 2.5in eSATA USB External Hard Drive Enclosure for SATA HDD , StarTech.com InfoSafe 3.5" eSATA & USB 2.0 SATA Drive Enclosure, 5 Drive 2.5"/3.5" eSATA RAID SATA HD Enclosure, 5.25" eSATA/USB 2.0 SATA Optical Drive Enclosure, Dual 3.5" Drive eSATA to SATA HD Enclosure
Length: 30cm
Price Range Ex VAT: 0 - 50
