StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention
Quicklinx: 5CB7WS00 Mfr#: ICUSB2321X
Type: Serial adapter
Compatibility: PC
Interface: USB
£21.31 ex VAT
£25.57 inc VAT
The ICUSB2321X Professional grade USB Serial Adapter cable converts a USB 2.0 port into an RS232 serial port allowing you to connect to, monitor and control your serial devices. A durable, single cable design makes this the perfect solution for mobile technicians/administrators that require serial connectivity. Once connected, the USB to serial adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading the serial peripheral for USB compatibility.
StarTech.com USB to Serial Adapter - 1 Port - COM Port Retention - Texas Instruments TIUSB3410 - USB to RS232 Adapter Cable (ICUSB2321X) - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
3.5 cm 1.3 cm
Length
42 cm
33 g
RS-232
Data Transfer Rate
920 Kbps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 32-bit Edition
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
920 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
FCC, RoHS
Software Included
Drivers & Utilities
3.5 cm
1.3 cm
Length
42 cm
33 g
5CB7 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.84
5CB7 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £14.62
5CB7 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £21.31
5CB7 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.07
Compatibility: PC
Interface: USB
Price Range Ex VAT: 0 - 50
