StarTech.com 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage
Quicklinx: 4JDYWS00 Mfr#: PCI1S950DV
Add an RS232 Serial port through a PCI expansion slot. The PCI1S950DV 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage offers a high performance 16950 UART channel/port for connecting any new or legacy serial peripheral, with data transfer rates of up to 460Kbps.
A cost-effective solution for connecting serial modems, POS devices, printers, ISDN terminal adapters and more, and offers dual voltage support, allowing you to use a PCI (5V) or PCI-X (3.3V) slot for installation.
A versatile solution, the PCI Serial card supports several current and legacy versions of Windows, plus IRQ sharing and a PCI plug and play interface to guarantee convenient, hassle-free serial device connections. Suitable for installation in standard or small form factor PC cases, the PCI serial card includes an optional low profile/half-height bracket for easy installation.
StarTech.com 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage - serial adapter - PCI-X - RS-232
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI-X
PCI Specification Revision
PCI 2.2
Bus Voltage
Universal (3.3 V & 5.0 V)
Ports
RS-232
RS-232
Data Transfer Rate
460 Kbps
Microsoft Windows NT 4.0, Linux, Microsoft Windows 95/98/ME/2000/XP
P/N: PEX2PCI4, PEX2PCIE4L
Serial adapter
PCI-X
PCI 2.2
Bus Voltage
Ports
RS-232
Wired
RS-232
Data Transfer Rate
460 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI-X
Low-profile bracket, full-height bracket
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
