Add an RS232 Serial port through a PCI expansion slot. The PCI1S950DV 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage offers a high performance 16950 UART channel/port for connecting any new or legacy serial peripheral, with data transfer rates of up to 460Kbps.
A cost-effective solution for connecting serial modems, POS devices, printers, ISDN terminal adapters and more, and offers dual voltage support, allowing you to use a PCI (5V) or PCI-X (3.3V) slot for installation.
A versatile solution, the PCI Serial card supports several current and legacy versions of Windows, plus IRQ sharing and a PCI plug and play interface to guarantee convenient, hassle-free serial device connections. Suitable for installation in standard or small form factor PC cases, the PCI serial card includes an optional low profile/half-height bracket for easy installation.
- StarTech.com 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage - serial adapter - PCI-X - RS-232
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI-X
- PCI Specification Revision
- PCI 2.2
- Bus Voltage
- Universal (3.3 V & 5.0 V)
- Ports
- RS-232
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460 Kbps
- System Requirements
- Microsoft Windows NT 4.0, Linux, Microsoft Windows 95/98/ME/2000/XP
- Limited lifetime warranty
- Designed For
- P/N: PEX2PCI4, PEX2PCIE4L
- Serial adapter
- Form Factor
- PCI-X
- PCI 2.2
- Bus Voltage
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 460 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI-X
- Included Accessories
- Low-profile bracket, full-height bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
- Designed For
