StarTech.com 1 Port PCI Parallel Adapter Card
Customer rating: 4.0* (Write a review)
Quicklinx: 3ZR8WS00 Mfr#: PCI1PECP
Type: Parallel adapter
Compatibility: PC
Interface: PCI
  • Windows 8 (32/64 bits)
Hurry, only 3 left in stock!
£20.24 ex VAT
£24.28 inc VAT
Add a high-speed parallel port (EPP/ECP) to your desktop computer through a PCI expansion slot. This high performance PCI based EPP/ECP parallel adapter card can be installed in a computer PCI slot to add one IEEE 1284 parallel port to your PC. A cost-effective way to connect parallel devices to the computer, with data transfer speeds of up to 1.5 Mbps (up to 3 times faster than on-board parallel ports).
The adapter card supports EPP, ECP, SPP and BPP parallel communications, and is simple to install in virtually any PC. The card supports Windows Vista, XP, ME, 2000, 98, 95, NT4, DOS and Linux, plus IRQ sharing and plug and play capabilities guarantee convenient, hassle-free connections to any parallel peripheral.
A complete dual profile solution, the PCI parallel adapter card provides both standard bracket and low profile/half-height brackets for adapting to slimline or small form factor system applications.
StarTech.com 1 Port PCI Parallel Adapter Card - parallel adapter
Parallel adapter
Plug-in card
Interface (Bus) Type
PCI
Ports
IEEE 1284
Parallel
Data Transfer Rate
1.5 Mbps
Microsoft Windows 95/98, Linux, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / NT, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Parallel adapter
Plug-in card
PCI
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
1.5 Mbps
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) - female - 1
Compatible Slots
1 x PCI
Plug and Play
Software Included
Drivers & Utilities
Limited warranty - parts and labour - lifetime - carry-in
3ZR8 StarTech.com 1 Port PCI Parallel Adapter Card In Stock £20.24
3ZR8 StarTech.com 1 Port Low Profile PCI Parallel Adapter Card In Stock £18.89
3ZR8 StarTech.com 6 ft Parallel Printer Cable In Stock £3.64
Customer reviews
Write a review for the StarTech.com 1 Port PCI Parallel Adapter Card here!
StarTech.com 1 Port Parallel PCI Card
Reviewed by John. Review Posted 23/07/2007
I bought one of these for my mother-in-law's new Vista PC. She has a parallel printer/scanner that she wanted to use and the machine didn't have any parallel ports. The physical install took about 5 minutes. The only fiddly part was finding the right drivers for Vista (they didn't come on the CD) but they are all there on startech.com's website. So, after about 15 minutes in total, there is now a reliable parallel port where previously there was none. Price is good too!
  • Overall 4*
  • Ease of use 4*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Compatibility: PC
Interface: PCI
Price Range Ex VAT: 0 - 50
