The PCI1P2 1-Port Parallel PCI Card adds one ECP/EPP/SPP/BPP IEEE 1284 port to your PC, with support for data transfer speeds of up to 1.8Mbps.
This versatile card offers compatibility with PCI or PCI-X expansion slots (3.3/5V, 32/64-bit), as well as a simple plug and play installation with support and drivers for a broad range of operating systems including Windows 7, Server 2008 R2, XP Embedded DOS, Linux and more. The PCI Parallel card also features IRQ sharing and hot swapping capabilities, which guarantee convenient, hassle-free connections to any parallel peripheral.
This product is a replacement for the PCI1P card.
- StarTech.com 1 Port PCI Parallel Adapter Card - parallel adapter - PCI-X - IEEE 1284
- Parallel adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI-X
- Ports
- IEEE 1284
- 6.1 cm x 12.1 cm x 1.3 cm
- 70 g
- Data Link Protocol
- Parallel
- Data Transfer Rate
- 1.8 Mbps
- System Requirements
- Microsoft DOS, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Linux 2.4.x, Microsoft Windows 95/98/ME/NT/2000/XP, Microsoft Windows Embedded Standard 2009, Linux 2.6.x, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / 7
- Limited lifetime warranty
- Parallel adapter
- Form Factor
- Plug-in card
- PCI-X
- Ports
- IEEE 1284
- Connectivity Technology
- Wired
- Parallel
- 1.8 Mbps
- 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
- Compatible Slots
- 1 x PCI-X
- EN 61000-3-2, EN 61000-3-3, EN55024, WHQL, EN55022 Class B, FCC Part 15 B, RoHS
- OS Required
- 6.1 cm
- 12.1 cm
- 1.3 cm
- 70 g
- Limited warranty - lifetime
- 0 °C
- 60 °C
- 5 - 95%
