Add 1 high-speed RS-232 serial port to your low profile/small form factor computer with a PCI expansion slot.
This 16550 Serial PCI Card can be installed in a computer PCI slot to add an RS232 serial port - a cost-effective solution for connecting any new serial device or old legacy serial device, with data transfer rates of up to 115.2 Kbps. The serial card features a low profile/half-height bracket, suitable for installation in low profile/small form factor computer cases.
Perfect for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more, to your system, the PCI Serial card supports IRQ sharing and operates flawlessly with Windows 7, Server 2008 R2, Vista, XP, Server 2003, 2000, ME, 98, 95, NT4, 3.1, DOS and Linux. Saving time and hassle, the PCI serial card can be connected in minutes through simple plug and play installation.
- StarTech.com 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART - serial adapter - PCI - RS-232
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI
- Ports
- RS-232
- 12 cm x 5.5 cm
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 920 Kbps
- System Requirements
- Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 920 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI - low-profile
- Plug and Play, CSA, UL, TUV, CB
- OS Required
- 12 cm
- 5.5 cm
- Limited warranty - lifetime
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
