StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile
Quicklinx: 8GTXWS00 Mfr#: ST1000SPEX2
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: Mac, PC, Unix
Type: Network adapter
Hurry, only 3 left in stock!
£15.00 ex VAT
£18.00 inc VAT
Add a 10/100/1000Mbps Ethernet port to any PC through a PCI Express slot. The ST1000SPEX2 PCIe Gigabit Ethernet Network Card adds a 10/100/1000 Mbps compatible RJ45 Ethernet port to a PCI Express-enabled client, server or workstation, providing a convenient addition or replacement networking interface.
Compliant with IEEE 802.3/u/ab standards, and with support for 9K Jumbo Frames, VLAN tagging and Wake on LAN (WOL), this versatile Gigabit NIC/Server Adapter delivers rock-solid performance.
Plus, the card includes both full profile and low profile/half-height installation brackets for installation in a wide range of computer/server chassis, regardless of form factor.
StarTech.com 1 Port PCIe Gigabit Network Server Adapter NIC Card - Dual Profile - Gigabit Desktop Adapter REV E Intel 6 Chip support (ST1000SPEX2) - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Ports
Gigabit Ethernet
2 cm x 12 cm x 8 cm
36 g
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
1 x Realtek Semiconductor RTL8111E
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
P/N: ET91000SM10, ET91000SM20
Network adapter
PCI Express x1
Ports
Gigabit Ethernet
Wired
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity
Full duplex capability, VLAN support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Jumbo Frames support
Processor / Memory
1 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
2 cm
12 cm
8 cm
36 g
70 °C
10 - 90%
8GTX StarTech.com 10' Cat5e Patch Cable Black In Stock £3.32
8GTX StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £4.65
8GTX StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £3.85
8GTX StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card In Stock £10.74
8GTX StarTech.com 10ft Blue Cat5 UTP Patch Cable In Stock £3.32
8GTX StarTech.com 6ft Blue Cat5e UTP Patch Cable In Stock £2.76
8GTX StarTech.com 1 Port PCI 10/100/1000 32 Bit Gigabit Ethernet Network Adapter Card In Stock £8.59
8GTX StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable In Stock £122.85
8GTX StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile In Stock £15.00
8GTX StarTech.com 1 Port PCI Express PCIe Gigabit NIC Server Adapter Network Card - Low Profile In Stock £14.99
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 0 - 50
