The PEX1PLP PCIe Parallel Adapter card can be installed in a PCI Express (PCIe) x1 slot, allowing you to connect EPP/ECP parallel peripherals to any computer, while relying on a native, single-chip design (Oxford OXPCIe952) that harnesses the capability of true PCI Express - ensuring maximum performance and reliability.
This high performance SPP/EPP/ECP parallel card adds 1 DB25 parallel port, perfect for connecting printers, scanners, CD-R/RW drives, memory card readers, bar code scanners and more. With the added convenience of plug-and-play capability, installing the parallel adapter card is hassle-free!
- StarTech.com 1 Port PCI Express Low Profile Parallel Adapter Card - SPP/EPP/ECP Parallel Card (PEX1PLP) - parallel adapter - PCIe - IEEE 1284
- Parallel adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.0a
- Ports
- IEEE 1284
- 2.1 cm x 11 cm x 12 cm
- 65 g
- Data Link Protocol
- Parallel
- Data Transfer Rate
- 2.5 Mbps
- System Requirements
- Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- 2-year warranty
- Parallel adapter
- Form Factor
- PCI Express x1
- PCIe 1.0a
- Ports
- IEEE 1284
- Connectivity Technology
- Wired
- Parallel
- 2.5 Mbps
- 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Full-height bracket
- FCC, RoHS
- OS Required
- 2.1 cm
- 11 cm
- 12 cm
- 65 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 85%
