StarTech.com 1 Port PCI Express Low Profile Parallel Adapter Card - SPP/EPP/ECP
Quicklinx: 7B76WS00 Mfr#: PEX1PLP
Type: Parallel adapter
Compatibility: PC
Interface: PCI Express x1
18 in stock
£24.60 ex VAT
£29.52 inc VAT
The PEX1PLP PCIe Parallel Adapter card can be installed in a PCI Express (PCIe) x1 slot, allowing you to connect EPP/ECP parallel peripherals to any computer, while relying on a native, single-chip design (Oxford OXPCIe952) that harnesses the capability of true PCI Express - ensuring maximum performance and reliability.
This high performance SPP/EPP/ECP parallel card adds 1 DB25 parallel port, perfect for connecting printers, scanners, CD-R/RW drives, memory card readers, bar code scanners and more. With the added convenience of plug-and-play capability, installing the parallel adapter card is hassle-free!
StarTech.com 1 Port PCI Express Low Profile Parallel Adapter Card - SPP/EPP/ECP Parallel Card (PEX1PLP) - parallel adapter
Parallel adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Ports
IEEE 1284
2.1 cm x 11 cm x 12 cm
65 g
Parallel
Data Transfer Rate
2.5 Mbps
Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Parallel adapter
PCI Express x1
PCIe 1.0a
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
2.5 Mbps
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
Compatible Slots
1 x PCI Express x1
Full-height bracket
FCC, RoHS
2.1 cm
11 cm
12 cm
65 g
50 °C
5 - 85%
7B76 StarTech.com 1 Port Low Profile PCI Parallel Adapter Card In Stock £19.13
7B76 StarTech.com 1 Port PCI Express Dual Profile Parallel Adapter Card - SPP/EPP/ECP In Stock £18.76
7B76 StarTech.com 1 Port PCI Express Low Profile Parallel Adapter Card - SPP/EPP/ECP In Stock £24.60
Compatibility: PC
Price Range Ex VAT: 0 - 50
