This PCI Express IDE Controller Adapter Card provides a cost-effective way to use legacy drives with modern computers, by converting a PCI Express port into an IDE port.
Providing data burst transfer rates of up to 133MBps and support for PIO 0/1/2/3/4 and UDMA 33/66/100/133 operating modes, the IDE controller card offers an efficient way to add an IDE channel with support for two IDE drives on the same channel.
A complete dual profile solution, the PCI Express IDE controller card provides both standard and low profile brackets for adapting to slimline or small form factor system applications.
- StarTech.com 1 Port PCI Express IDE Controller Adapter Card - Storage controller - ATA - 133 MBps - PCIe x1 - PEX2IDE - storage controller - ATA - PCIe x1
- Storage controller - plug-in card
- Bus Type
- PCIe x1
- Interface
- ATA
- Data Transfer Rate
- 133 MBps
- Supported Devices
- Hard drive
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP, Windows 10 (32/64 bits)
- Limited lifetime warranty
- Host Bus
- PCIe x1
Storage Controller
- Interface
- ATA
- 133 MBps
- Supported Devices
- Hard drive
- 1 x ATA (internal)
- Compatible Slots
- 1 x PCI Express x1
- Cables Included
- 1 x IDE cable - internal - 46 cm
- FCC, RoHS
- OS Required
- Limited warranty - lifetime
