StarTech.com 1 Port PCI Express Dual Profile Parallel Adapter Card -  SPP/EPP/ECP
Quicklinx: 67CCWS00 Mfr#: PEX1P
Type: Parallel adapter
Compatibility: PC
Interface: PCI Express x1
48 in stock
£18.76 ex VAT
£22.51 inc VAT
Add a parallel port to your desktop computer through a PCI Express slot; features both standard and half-height mounting brackets. The PEX1P PCIe parallel adapter card can be installed in a PCI Express (PCIe) slot, allowing you to connect EPP/ECP parallel peripherals to any computer system. Relying on a native single-chip design (Oxford OXPCIe952), this adapter harnesses the true capability of PCI Express - ensuring maximum performance and reliability.
This high performance SPP/EPP/ECP parallel card adds one DB25 parallel port, perfect for connecting printers, scanners, CD-R/RW drives, memory card readers, bar code scanners and more. With the added convenience of plug and play capability, installing the parallel adapter card is hassle-free!
The PCIe parallel adapter card includes both standard and half-height/low profile mounting brackets.
StarTech.com 1 Port PCI Express Dual Profile Parallel Adapter Card - SPP/EPP/ECP - 1x DB25 IEEE 1284 PCIe Parallel Card (PEX1P) - parallel adapter - PCIe - IEEE 1284
Parallel adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Bus Voltage
Universal (3.3 V & 5.0 V)
Ports
IEEE 1284
2.1 cm x 11 cm x 12 cm
65 g
Parallel
Data Transfer Rate
2.5 Mbps
Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Parallel adapter
Plug-in card
PCI Express x1
PCIe 1.0a
Bus Voltage
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
2.5 Mbps
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC
Software Included
Drivers & Utilities
2.1 cm
11 cm
12 cm
65 g
67CC StarTech.com 1 Port Low Profile PCI Parallel Adapter Card In Stock £19.13
67CC StarTech.com 1 Port PCI Express Dual Profile Parallel Adapter Card - SPP/EPP/ECP In Stock £18.76
Compatibility: PC
Stock Status: In stock
