StarTech.com 1 Port PCI Express 10 Gigabit Ethernet Network Card - PCIe x4 10Gb NIC
Quicklinx: 9MLMWS00 Mfr#: ST10000SPEX
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: Mac, PC
Type: Network adapter
£137.38 ex VAT
£164.85 inc VAT
Add a 10 Gigabit Ethernet port (10 Gbps) to a client, server or workstation through a PCI Express slot. The ST10000SPEX PCI Express 10 Gbps Network Card lets you add a 10-Gigabit Ethernet port to your server or high-powered workstation through a PCI Express x4 (or higher) slot.
With rising demand on network resources due to large file transfers, increase in network users and multimedia content, more bandwidth is often required at various levels of your infrastructure. This 10 Gb NIC offers a cost-effective solution for your file or application server or even a high-powered workstation to transfer more data, faster.
Fully compliant with the IEEE 802.3an 10GBASE-T standard, the card offers added bandwidth over standard Cat 6a cabling, to meet your network needs without an overhaul of your infrastructure wiring, or a costly upgrade to fiber. The 10 Gbps network card also offers compatibility with VMWare ESXi 5.0/5.1 and Microsoft Hyper-V virtualization software and iSCSI support to combine LAN and SAN functions.
For peak operating efficiency, the 10GBASE-T card features the Tehuti TN4010 chipset, compliant with 802.3az Energy Efficient Ethernet and with significantly reduced power consumption versus the popular Intel X540-AT1 chipset. The reduced power consumption also helps to minimize heat generated by the card, to avoid increasing the operating temperature within your server case.
The card also supports 16K Jumbo Frames, 802.1q VLAN tagging and is backward compatible with 1 Gbps and 100 Mbps network connections. For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
StarTech.com 1 Port PCI Express 10 Gigabit Ethernet Network Card - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x4
Ports
10Gb Ethernet x 1
1.9 cm x 8.2 cm x 12 cm
90 g
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T
100Mb LAN, GigE, 10 GigE
Data Transfer Rate
10 Gbps
1 x TN4010 - Tehuti
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.3an, IEEE 802.3az
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, VMware ESXi 5.1, VMware ESXi 5.0, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, VMware ESXi 6.0, VMware ESXi 6.5, Microsoft Windows Hyper-V Server, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.10.3 - 10.14
Network adapter
PCI Express x4
Ports
10Gb Ethernet x 1
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Full duplex mode, Jumbo Frames support, Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet, tagged VLAN
Processor / Memory
1 x TN4010 - Tehuti
1 x 10GBase-T - RJ-45
Low-profile bracket, full-height bracket
FCC, RoHS
Software Included
Drivers & Utilities
1.9 cm
8.2 cm
12 cm
90 g
9MLM StarTech.com 10 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable In Stock £11.62
9MLM StarTech.com 10 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable In Stock £11.62
9MLM StarTech.com 3 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable In Stock £7.22
9MLM StarTech.com 3 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable In Stock £7.09
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 100 - 150
