StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card
Quicklinx: 5FFZWS00 Mfr#: PEX100S
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
43 in stock
£10.71 ex VAT
£12.85 inc VAT
This PCI Express based 10/100 Ethernet Card provides a simple way to connect a PCIe enabled server or workstation to a 10/100 Ethernet network and offers a broad range of features and functions, including support for both Full and Half Duplex operation as well as Wake On LAN (WOL) Power Management.
The PEX100S Ethernet Card includes both standard and low profile brackets and is compatible with most mATX (Slimline) and ATX system form factors, and features Auto MDI/MDIX automatic configuration, which helps to simplify installation and configuration.
StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card (PEX100S) - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Ports
10/100 Ethernet
2.1 cm x 12 cm
45 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
1 x Realtek Semiconductor RTL8101E
IEEE 802.3x
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019
Network adapter
PCI Express x1
Ports
10/100 Ethernet
Wired
Cabling Type
Data Transfer Rate
100 Mbps
Status Indicators
Port transmission speed
Full duplex capability, auto-sensing per device, auto-negotiation, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), half duplex mode
IEEE 802.3x
Processor / Memory
1 x 100Base-TX - RJ-45
Compatible Slots
1 x PCI Express x1
Low-profile bracket, full-height bracket
FCC, RoHS
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
2.1 cm
12 cm
45 g
Limited warranty - lifetime
5FFZ StarTech.com 1 Port Low Profile PCI 10/100 Mbps Ethernet Network Adapter Card In Stock £7.06
5FFZ StarTech.com 1 Port PCI 10/100 Mbps Ethernet Network Adapter Card In Stock £5.71
5FFZ StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.64
5FFZ StarTech.com 25 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £5.16
5FFZ StarTech.com 15 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £3.82
5FFZ StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card In Stock £10.71
5FFZ StarTech.com 10ft Blue Cat5 UTP Patch Cable In Stock £3.32
5FFZ StarTech.com 6ft Blue Cat5e UTP Patch Cable In Stock £2.76
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: PC
Price Range Ex VAT: 0 - 50
