This 1 Port Serial ExpressCard Adapter lets you add an RS232 serial port to your laptop or ExpressCard-equipped desktop computer.
The serial ExpressCard is designed based on a single-chip architecture (as opposed to cards that use a "bridge chip"), providing native PCI Express communication for greater performance and reliability, and reduced power consumption and CPU load.
An included 34mm to 54mm ExpressCard stabilizer adapter bracket allows the EC2S952 to fit in both 34mm and 54mm ExpressCard slots. This serial adapter features 128-byte FIFO communication and a high performance 16C950 UART.
Providing optimal communication with RS232 serial devices, the serial ExpressCard supports data transfer rates of up to 460Kbps, saving time and hassle.
- StarTech.com 1 Port Native ExpressCard RS232 Serial Adapter Card with 16952 UART - serial adapter
- Serial adapter
- Form Factor
- Plug-in module
- Interface (Bus) Type
- ExpressCard/34
- Ports
- RS-232
- 4.5 cm x 11.5 cm x 2 cm
- 34 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460 Kbps
- System Requirements
- Microsoft Windows 95/98/ME/XP, Microsoft Windows Vista
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in module
- ExpressCard/34
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 460 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x ExpressCard/34 , 1 x ExpressCard/54
- FCC, RoHS
- OS Required
- 4.5 cm
- 11.5 cm
- 2 cm
- 34 g
- Limited warranty - lifetime
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M | In Stock | £3.81 |
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F | In Stock | £4.27 |
StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART | In Stock | £26.58 |
StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART | In Stock | £65.28 |
StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F | In Stock | £16.29 |
StarTech.com 1 Port Native ExpressCard RS232 Serial Adapter Card with 16950 UART | In Stock | £37.55 |
StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F | In Stock | £4.31 |
