StarTech.com 1 Port Native ExpressCard RS232 Serial Adapter Card with 16950 UART
Quicklinx: 6BD1WS00 Mfr#: EC1S952
This 1 Port Serial ExpressCard Adapter lets you add an RS232 serial port to your laptop or ExpressCard-equipped desktop computer.
The serial ExpressCard is designed based on a single-chip architecture (as opposed to cards that use a "bridge chip"), providing native PCI Express communication for greater performance and reliability, and reduced power consumption and CPU load.
An included 34mm to 54mm ExpressCard stabilizer adapter bracket allows the EC2S952 to fit in both 34mm and 54mm ExpressCard slots. This serial adapter features 128-byte FIFO communication and a high performance 16C950 UART.
Providing optimal communication with RS232 serial devices, the serial ExpressCard supports data transfer rates of up to 460Kbps, saving time and hassle.
StarTech.com 1 Port Native ExpressCard RS232 Serial Adapter Card with 16950 UART - ExpressCard 54 Serial Card (EC1S952) - serial adapter - ExpressCard - RS-232
Serial adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
RS-232
4.5 cm x 11.5 cm x 2 cm
34 g
RS-232
Data Transfer Rate
460 Kbps
Microsoft Windows 95/98/ME/XP, Microsoft Windows Vista
Serial adapter
Plug-in module
ExpressCard/34
Ports
RS-232
Wired
RS-232
Data Transfer Rate
460 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x ExpressCard/34 , 1 x ExpressCard/54
FCC, RoHS
4.5 cm
11.5 cm
2 cm
34 g
Limited warranty - lifetime
6BD1 StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F In Stock £21.42
6BD1 StarTech.com Serial Null Modem Adapter In Stock £5.19
6BD1 StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F In Stock £5.19
