StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter with Isolation
Quicklinx: 67CBWS00 Mfr#: ICUSB422IS
Type: Serial adapter
Compatibility: PC
Interface: USB
Hurry, only 1 left in stock!
£72.43 ex VAT
£86.91 inc VAT
Add an R422/485 serial port to your laptop or desktop computer through USB.
The ICUSB422IS 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter w/ Isolation connects to a computer using USB and allows you to connect any RS-422 or RS-485 serial device via the provided DB9 port or hard-wired to the terminal block. The USB to serial adapter features circuit isolation to ensure that sensitive controls and devices will not be damaged while connected, making it a viable solution for connecting costly industrial serial devices. The RS422/485 Converter receives full power via the host USB connection, and provides power to the attached serial device without requiring an external power adapter. Designed to provide a durable serial solution, the USB to RS422/485 Converter is ruggedly constructed and can be mounted nearly anywhere.
StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter w/ Isolation (ICUSB422IS) - serial adapter
Serial adapter
External
Interface (Bus) Type
USB
5.4 cm x 2.3 cm x 9.3 cm
300 g
RS-422, RS-485
Data Transfer Rate
921.6 Kbps
Microsoft Windows Server 2003, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
Serial adapter
External
USB
Wired
RS-422, RS-485
Data Transfer Rate
921.6 Kbps
USB powered
1 x RS-422/485 - 9 pin D-Sub (DB-9) , 1 x RS-422/485 - terminal block
1 x USB - 4 pin USB Type B
1 x USB cable (external) - 1.8 m
FCC, RoHS
Software Included
Drivers & Utilities
5.4 cm
2.3 cm
9.3 cm
300 g
55 °C
5 - 95%
67CB StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.84
67CB StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.29
67CB StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.90
67CB StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £3.89
Compatibility: PC
Interface: USB
Price Range Ex VAT: 50 - 100
