StarTech.com 1 Port Low Profile Native PCI Express Serial Card w/ 16950
Quicklinx: 76P8WS00 Mfr#: PEX1S952LP
Type: Serial adapter
Compatibility: PC, Unix
Interface: PCI Express x1
£33.09 ex VAT
£39.70 inc VAT
Low Profile PCI-Express 16C950 Serial Card. The PEX1S952LP 1 Port Low Profile Native PCI Express RS232 Serial Adapter Card with 16950 UART adds an RS232 (DB9) Serial Port with data rates up to 460 Kbps to a computer through an available low profile PCIe slot, while relying on a native, single-chip design (Oxford OXPCIe952) that harnesses the capability of true PCI Express - ensuring maximum performance and reliability and reducing the load applied to the CPU by as much as 48% over conventional (bridge chip) serial cards.
The 1 port RS232 serial card features a half-height PCI Express mounting bracket that's designed specifically for low profile/small form factor computer cases, and includes an optional standard height bracket as well. Compatible with a broad range of operating systems including Windows and Linux for easy integration into mixed environments.
StarTech.com 1 Port Low Profile Native PCI Express RS232 Serial Card with 16950 UART - PCIe Serial Card - 1 Port LP RS232 Card (PEX1S952LP) - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.0a
Bus Voltage
3.3 V
Ports
RS-232
9 cm x 6.5 cm x 2 cm
48 g
RS-232
Data Transfer Rate
460 Kbps
Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Serial adapter
PCI Express x1
PCIe 1.0a
Bus Voltage
3.3 V
Ports
RS-232
Wired
RS-232
Data Transfer Rate
460 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9) - male - 1 (external)
Compatible Slots
1 x PCI Express x1
9 cm
6.5 cm
2 cm
48 g
Limited warranty - lifetime
76P8 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
76P8 StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
76P8 StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
76P8 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.22
76P8 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.10
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 0 - 50
