Product
Brand
StarTech.com 1 Port ISA RS232 Serial Adapter Card with 16550 UART
Quicklinx: 76SDWS00 Mfr#: ISA1S550
The StarTech.com ISA single port serial expansion card is a high performance serial add-in card providing PC workstations with an additional COM port for the connection of external peripherals. The card supports transfer rates of up to 115.2 Kbps for fast serial data transfer. Jumpers on the card provide complete easy configuration and complete compatibility as a basic COM port for any operating system.
StarTech.com 1 Port ISA RS232 Serial Adapter Card with 16550 UART - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
ISA
Ports
RS-232
Serial
Data Transfer Rate
460.8 Kbps
Microsoft Windows 3.x/95/98, Microsoft Windows 2000 / NT4.0
Serial adapter
Plug-in card
ISA
Ports
RS-232
Wired
Serial
Data Transfer Rate
460.8 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9) - male - 1
Compatible Slots
1 x ISA
Software Included
Drivers & Utilities
Limited warranty - parts and labour - lifetime
76SD StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
76SD StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
76SD StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.88
76SD StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
76SD StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
76SD StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
76SD StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
