StarTech.com 1 Port Industrial USB to RS232 Serial Adapter with 5KV Isolation & 15KV ESD Protection
Quicklinx: 920KWS00 Mfr#: ICUSB232IS
Type: Serial adapter
Compatibility: Mac, PC
Interface: USB
  • Windows 8 (32/64 bits)
£53.76 ex VAT
£64.51 inc VAT
Add a galvanically isolated RS232 serial port with ESD protection through a USB port - DIN Rail Mountable. The ICUSB232IS Industrial USB to Serial Adapter lets you add a galvanically isolated RS232 serial port with ESD protection through a USB port and offers a durable DIN Rail-mountable design.
Ideal for industrial environments, the USB serial adapter features an integrated 5KV galvanic isolation circuit and 15KV ESD protection, to protect costly and often sensitive control equipment against electrical damage. An extended operating temperature range (-30°C to 75°C) also helps to ensure performance in harsh environments.
For fast communication with serial peripherals, the adapter features an integrated FTDI chipset, supporting baud rates up to 921Kbps. The adapter also features COM retention that automatically retains COM Port assignments, even through a reboot.
The ICUSB232IS serial adapter is compatible with Windows, Windows CE, Mac OS and Linux which makes it easy to integrate into mixed environments.
StarTech.com USB to Serial Adapter - Industrial - 5KV Isolation and 15KV ESD Protection - FTDI - USB to RS232 Adapter Cable (ICUSB232IS) - serial adapter
Serial adapter
DIN rail mountable
Interface (Bus) Type
USB
Ports
RS-232 x 1
9.3 cm x 4.2 cm x 2.2 cm
25 g
RS-232
Data Transfer Rate
921.6 Kbps
Linux 2.6.x or later, Apple MacOS X 10.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE .NET 4.2 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Serial adapter
DIN rail mountable
USB
Ports
RS-232 x 1
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
Transmit, receive
Flow control, USB powered
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB cable (external) - 1 m
FCC, RoHS
Software Included
Drivers & Utilities
9.3 cm
4.2 cm
2.2 cm
25 g
-40 °C
75 °C
5 - 95% (non-condensing)
920K StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.84
920K StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.90
920K StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £72.72
920K StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips In Stock £40.46
920K StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £66.22
920K StarTech.com 3 ft Straight Through Serial Cable - DB9 M/F In Stock £3.30
920K StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £118.32
920K StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £3.41
920K StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.30
920K StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.07
Compatibility: Mac
Compatibility: PC
Interface: USB
Price Range Ex VAT: 50 - 100
