StarTech.com 1 Port Industrial USB to RS232 Serial Adapter with 5KV Isolation & 15KV ESD Protection
Quicklinx: 920KWS00 Mfr#: ICUSB232IS
Add a galvanically isolated RS232 serial port with ESD protection through a USB port - DIN Rail Mountable. The ICUSB232IS Industrial USB to Serial Adapter lets you add a galvanically isolated RS232 serial port with ESD protection through a USB port and offers a durable DIN Rail-mountable design.
Ideal for industrial environments, the USB serial adapter features an integrated 5KV galvanic isolation circuit and 15KV ESD protection, to protect costly and often sensitive control equipment against electrical damage. An extended operating temperature range (-30°C to 75°C) also helps to ensure performance in harsh environments.
For fast communication with serial peripherals, the adapter features an integrated FTDI chipset, supporting baud rates up to 921Kbps. The adapter also features COM retention that automatically retains COM Port assignments, even through a reboot.
The ICUSB232IS serial adapter is compatible with Windows, Windows CE, Mac OS and Linux which makes it easy to integrate into mixed environments.
StarTech.com USB to Serial Adapter - Industrial - 5KV Isolation and 15KV ESD Protection - FTDI - USB to RS232 Adapter Cable (ICUSB232IS) - serial adapter - USB - RS-232 x 1
Serial adapter
DIN rail mountable
Interface (Bus) Type
USB
Ports
RS-232 x 1
9.3 cm x 4.2 cm x 2.2 cm
25 g
RS-232
Data Transfer Rate
921.6 Kbps
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.x, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux Kernel 4.x, Microsoft Windows Server 2019, Linux LTS versions only, Linux Kernel 5.x, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Serial adapter
DIN rail mountable
USB
Ports
RS-232 x 1
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
Transmit, receive
Flow control, USB powered
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB cable (external) - 1 m
FCC, RoHS
Software Included
Drivers & Utilities
9.3 cm
4.2 cm
2.2 cm
25 g
-40 °C
75 °C
5 - 95% (non-condensing)
920K StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.75
920K StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.33
920K StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £108.11
920K StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips In Stock £60.15
920K StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.05
920K StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £102.11
920K StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £175.88
920K StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.51
920K StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.33
920K StarTech.com USB to RS232 Serial Adapter In Stock £16.35
920K StarTech.com 4 Port USB to Serial Hub In Stock £79.29
920K StarTech.com 4-Port USB to Serial Adapter In Stock £244.59
920K StarTech.com 8-Port USB to Serial Adapter In Stock £392.42
