Your basket is empty
StarTech.com 1 Port Industrial RS-232 / 422 / 485 Serial to IP Ethernet Device Server
Quicklinx: 98F7WS00 Mfr#: NETRS232485
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Remotely manage an industrial RS232 or RS422/485 serial device over an IP network, with redundant 10/100 Ethernet ports. The NETRS232485 Serial Device Server lets you remotely manage an industrial RS232/422/485 serial device over a local or wide area network (LAN/WAN), with redundant power inputs and dual 10/100Mbps Ethernet ports.
To minimize downtime, this intuitive dual Ethernet serial over IP solution maintains connection to your critical equipment by automatically switching to its secondary LAN port within 10 milliseconds of a network failure or disruption.
Ideal for industrial environments, the serial to Ethernet device server accepts wide-range 12-48V DC power input via a terminal block or an optional DC jack, enabling you to add redundant power with a secondary adapter (e.g. 12V DC 1.5A Power Adapter SKU: IM12D1500P - sold separately), keeping the device server functional in the event of power surges or failures.
This device server supports baud rates up to 460.8Kbps which provides a smooth, high-speed connection to your serial devices. The device server also offers support for HTTPS, SSH and SSL to ensure secure communication, while integrating remote Telnet configuration and support for IP, HTTP, ICMP, DHCP, ARP, TCP and UDP protocols. You can customize the serial device server to suit your application with versatile browser-based or virtual com port software configuration.
Ensuring performance in harsh environments, this serial device server offers 8KV air, and 4KV contact ESD (Electrostatic Discharge) Protection, and features a rugged, IP-30 case design that is both DIN rail and wall-mountable, with an extended operating temperature range (-40°C to 70°C).
StarTech.com 1 Port Industrial RS-232/422/485 Serial Ethernet Device Server - device server
Device server
External
Ethernet, Fast Ethernet, RS-232, RS-422, RS-485
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits)
2.94 cm x 7.2 cm x 12.34 cm
327 g
5 years warranty
Device server
2.94 cm
7.2 cm
12.34 cm
327 g
Enclosure Colour
External
Wired
Data Transfer Rate
460.8 Kbps
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, PPPoE, SMTP, BOOTP, DHCP, DNS, DDNS
Remote Management Protocol
SNMP 1, SNMP 2c, SSH
Encryption Algorithm
128-bit SSL
Authentication Method
Secure Shell (SSH)
1 x RS-232/422/485 - DB-9 , 2 x 100Base-TX - RJ-45
MTBF
533,615 hour(s)
FCC, RoHS, IP30
External power adapter
Software Included
Drivers & Utilities
Limited warranty - 5 years
-40 °C
70 °C
5 - 95% (non-condensing)
98F7 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
98F7 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
98F7 StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.49
98F7 StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £3.88
98F7 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £9.45
98F7 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
