StarTech.com 1 Port ExpressCard Laptop Parallel Adapter Card -  SPP/EPP/ECP
Quicklinx: 67C6WS00 Mfr#: EC1PECPS
Type: Parallel adapter
Compatibility: PC
Interface: ExpressCard/34
£47.85 ex VAT
£57.42 inc VAT
This ExpressCard Parallel Adapter turns an ExpressCard slot into a Parallel port, allowing you to connect parallel devices to a laptop computer. The card is PCI Express (x1) based, ensuring faster data transfer rates between host and peripheral than USB-based ExpressCards - providing a cost-effective way to bridge the compatibility gap between your laptop and legacy devices.
A convenient solution for adding a parallel printer or scanner, simply insert the adapter (EC1PECPS) into an available 34mm or 54mm ExpressCard slot and connect the parallel device to the adapter SPP/EPP/ECP parallel port. The adapter card is WHQL certified, so software installation is automated.
StarTech.com 1 Port ExpressCard Laptop Parallel Adapter Card - SPP/EPP/ECP - ExpressCard 54 Serial Card - Parallel ExpressCard (EC1PECPS) - parallel adapter - ExpressCard - IEEE 1284
Parallel adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
IEEE 1284
4.4 cm x 11.5 cm x 2 cm
40 g
Parallel
Data Transfer Rate
1.5 Mbps
Microsoft DOS, Linux, Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP
P/N: ECBRACKET2
Parallel adapter
Plug-in module
ExpressCard/34
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
1.5 Mbps
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
Compatible Slots
1 x ExpressCard/34
WHQL, FCC, RoHS
Software Included
Drivers & Utilities
4.4 cm
11.5 cm
2 cm
40 g
P/N: ECBRACKET2
67C6 StarTech.com 2 Port PCI Parallel Adapter Card - EPP/ECP In Stock £34.29
67C6 StarTech.com 1 Port PCI Parallel Adapter Card In Stock £20.48
67C6 StarTech.com 1 Port Low Profile PCI Parallel Adapter Card In Stock £19.13
Compatibility: PC
Price Range Ex VAT: 0 - 50
