StarTech.com 1 Port eSATA + 1 Port SATA PCI SATA Controller Card w/ LP Bracket
Quicklinx: 67CLWS00 Mfr#: PCIESATA2I
Type: Storage controller
Controller Interface: Serial ATA-150 / eSATA
Interface: PCI
Compatibility: PC
Hurry, only 3 left in stock!
£12.53 ex VAT
£15.03 inc VAT
Add an internal SATA port and an external SATA (eSATA) port to your desktop computer through a PCI expansion slot. This PCI based SATA Controller Card allows you to turn a PCI slot into one internal SATA and one external SATA (eSATA) connection. Supporting SATA 150 hard drives, and data transfer rates of up to 1.5Gbps, this controller card is the perfect solution if you need an extra SATA port or want to externalize your storage.
StarTech.com 1 Port eSATA + 1 Port SATA PCI SATA Controller Card - storage controller - SATA 1.5Gb/s / eSATA - PCI
Storage controller - plug-in card - low profile
Bus Type
PCI
Data Transfer Rate
1.5 Gbit/s
Supported Devices
Hard drive
Channel Qty
2
Max Storage Devices Qty
2
Microsoft Windows 98 Second Edition, Microsoft Windows Vista / 2000 / XP
12.1 cm x 5.4 cm x 2 cm
47 g
Host Bus
PCI
Storage Controller
Data Transfer Rate
1.5 Gbit/s
Supported Devices
Hard drive
Channel Qty
2
2
VIA VT6421
1 x SATA 1.5Gb/s - eSATA (external) , 1 x SATA 1.5Gb/s - SATA (internal)
Compatible Slots
1 x PCI
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
12.1 cm
5.4 cm
2 cm
47 g
67CL StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £6.82
67CL StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.22
67CL StarTech.com 1 Port eSATA + 1 Port SATA PCI SATA Controller Card w/ LP Bracket In Stock £12.53
Interface: PCI
Compatibility: PC
Price Range Ex VAT: 0 - 50
