Add a DB9 serial port to the rear panel of your computer. The PLATE9M 9 inch Serial Port Header Bracket adds a DB9 serial port to the rear panel of your computer, connecting to an IDC10 header connector on the motherboard.
Please refer to this product's Technical Specifications to ensure compatibility with your motherboard.
- StarTech.com 1 Port 9in DB9 Serial Port Bracket to 10 Pin Header - serial panel - DB-9 to 10 PIN IDC - 22.9 cm
- Serial panel
- Length
- 22.9 cm
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 10 PIN IDC - female
- Limited lifetime warranty
- Serial panel
- Length
- 22.9 cm
- Connector
