StarTech.com 1 Port 16in DB9 Serial Port Bracket to 10 Pin Header - Low Profile
Quicklinx: 84NYWS00 Mfr#: PLATE9M16LP
Length: 40.6cm
More than 50 In Stock
£5.31 ex VAT
£6.37 inc VAT
Add a DB9 serial port to the rear panel of a small form factor/low profile computer. The PLATE9M16LP (16 inch/0.4 m) Low Profile Serial Plate adds a DB9 serial port to the rear panel of a small form factor/low profile computer, connecting to an IDC10 header connector on the motherboard. This durable low profile DB9 bracket is constructed of high quality components.
StarTech.com 1 Port 16in DB9 Serial Port BRacket to 10 Pin Header - Low Profile - low profile DB9 Header - DB9 bRacket (PLATE9M16LP) - serial panel - DB-9 to 10 PIN IDC - 40.6 cm
Serial panel
Low profile
Length
40.6 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
10 PIN IDC - female
Grey
Serial panel
American Wire Gauge (AWG)
28
Low profile
Length
40.6 cm
Grey
Connector
10 PIN IDC - female
RoHS
84NY StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate In Stock £5.06
Length: 40.6cm
