StarTech.com 1 ft Short DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 76M2WS00 Mfr#: DISPLPORT1L
Type: DisplayPort
Length: 30cm
More than 50 in stock
£10.20 ex VAT
£12.24 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices, with reduced clutter. The DISPLPORT1L 1ft DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
The short 1-foot DisplayPort cable is perfect for mobile applications, such as connecting your laptop to a monitor and it provides a portable solution that makes it perfect for carrying as a laptop accessory.
StarTech.com 1 ft Short DisplayPort 1.2 Cable with Latches - DisplayPort 4k - DisplayPort cable - 30 cm
DisplayPort cable
Shielded
Latched, molded
Length
30 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
P/N: USB32DPPRO
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched, molded
Length
30 cm
Connector
20 pin DisplayPort - male
RoHS
P/N: USB32DPPRO
76M2 StarTech.com 25 ft DisplayPort Cable with Latches - M/M In Stock £45.83
76M2 StarTech.com 6 ft DisplayPort Video Extension Cable - M/F In Stock £23.22
76M2 StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £11.46
76M2 StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.72
76M2 StarTech.com 1 ft Short DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £10.20
76M2 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
Type: DisplayPort
Length: 30cm
Price Range Ex VAT: 0 - 50
