Product
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M
Quicklinx: 6BC1WS00 Mfr#: USBPNLBFBM1
Length: 30cm
More than 50 in stock
£4.26 ex VAT
£5.11 inc VAT
Standard delivery Delivered within 3-5 working days
For customized USB device solutions; allows the USB connection to be mounted on a secure easily accessible panel. The USBPNLBFBM1 USB B to USB Panel mount cable features a USB type B male connector on one end, and a USB panel mount B (female) molded connector on the other, providing a convenient solution for custom enclosures (e.g. internally mounted hard drives).
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M - USB cable - 30 cm
USB cable
Molded, thumbscrews
Length
30 cm
Connector
4 pin USB Type B - female
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
USB cable
Molded, thumbscrews
Length
30 cm
Connector
USB / USB 2.0, RoHS
Length: 30cm
Price Range Ex VAT: 0 - 50
